chronique SK2 en anglais
chronique de jazztimes (usa)
If you want two keyboards and you’re a stickler for authentic organ sounds, from percussion to that iconic Leslie, the SK2 is the right choice. Its twin 61-key ’boards deliver stunning renditions of B3, Vx, Farf and pipe organs. That’s not to mention the portability: The SK2, which we tested, weighs 35 pounds, and the SK1 is a mere 15. By comparison, a regular B3 is a whopping 400 pounds, and Hammond’s single-keyboard XK-3, released several years ago, is about 43 pounds. The SK2 is not particularly large, either: 37 1/4 inches wide by 17 7/8 inches front-to-back by 6 3/4 inches tall.
Along the back panel, it has jacks for MIDI, USB In/Out, 1/4-inch audio, an 8-pin Leslie, foot switch, damper and expression pedals. The jacks are marked on the top of the keyboard, which means you don’t have to lean over to figure out which plug goes where. The bottom and top are black metal and the sides are a mix of wood with a “hi-gloss polycarbonate finish” made to look like a deep cherry wood. It’s a sharp instrument.
With the SK2, it’s easy to assign and adjust different sounds to the upper and lower keyboards. There are knobs to quickly tweak the overdrive, effects, reverb, bass, frequency, gain and treble, and 10 assignable “favorites” buttons. You can have an on-the-nose B3 in the top keyboard and, say, a close replica of a Wurlitzer on the bottom. There’s also a song writer/recorder (though no preloaded backing tracks), and the SK2 holds 100 user and 100 preset patches. Both the SK1 and SK2 have the same number of presets, which, the company notes, account for every Hammond organ ever manufactured. You can also go to hammondorganco.com to download free expansion voices; Hammond plans to update the library with more tonewheel setups in the near future.
Aside from the organs, the Wurlitzer, clavinet and piano presets are among the SK2’s best, though it’s not a one-stop shop. The brass and flutes—and much of the other orchestral sounds, for that matter—can sound canned. The SK2’s selection of piano presets is extensive—a definite plus. The Wurlitzer emulations hold up well, but some sound thin when you nail the note. For my money, the Nord Electro still has better Rhodes and Wurlitzer electric piano sounds, though Hammond is closing the gap and trumps the Nord’s organ tones. And there are more than a few synthesizer presets, which, again, are admirable but not quite convincing enough to warrant trading in your current synthesizer.
The gorgeous organ tones are the SK2’s bread and butter. There are plenty of jazz and rock options, as well as a number of church organs (helpfully given names such as “quiet praise,” “dramatic praise” and “reflective praise”). Also worth noting: The keys’ waterfall action is right on the money for a Hammond.
The SK2 only has one set of drawbars, to keep the controls as simple and straightforward as possible, according to the manufacturer. You can switch between the upper and lower keyboards using a “drawbar select” button. For picky Hammond players who like to tweak their sound mid-performance, it’s a little annoying.
All too often, keyboard user manuals can be full of techno-babble, almost impossible to decipher. Not so with the SK2’s guide, which was easy to follow. And while Hammond sells a number of accessories for multiple keyboards, they’re also offering the heavy-duty, B3-type EXP-50 pedal specific to the SK1 and SK2.
With the SK1 and SK2, Hammond is off to a good start but still has a ways to go to be able to compete with some of the other, better orchestral synths on the market. When it comes to a classic organ sound in a moveable instrument, however, they’re unmatched.
Re: chronique SK2 en anglais
:fourire: :fourire: :fourire:
Si vous voulez deux claviers et vous êtes un maniaque de sons d'orgue authentiques , de percussion à cette emblématique Leslie , le SK2 est le bon choix . Ses 61 touches conseils jumeaux » offrent des interprétations superbes de B3 , Vx , Farf et orgues à tuyaux . C'est pour ne pas mentionner la portabilité : Le SK2 , que nous avons testé , pèse 35 livres, et le SK1 est un simple 15 . Par comparaison , un B3 régulière est un énorme £ 400 , et un seul clavier de XK -3 Hammond , publié il ya plusieurs années , est environ 43 livres . Le SK2 n'est pas particulièrement grande , soit : 37 1/4 pouces de large par 17 7/8 pouces avant -arrière par 6 3/4 pouces de hauteur .
Le long de la face arrière , il a prises pour MIDI , USB In / Out , audio 1/4-inch , un Leslie 8 broches , interrupteur au pied , amortisseur et pédales d'expression . Les prises sont marqués sur le haut du clavier , ce qui signifie que vous n'avez pas à se pencher pour comprendre quelle prise va où . Le bas et le haut sont en métal noir et les côtés sont un mélange de bois avec une finition " polycarbonate salut - gloss" faite pour ressembler à un bois profond de cerise . C'est un instrument tranchant .
Avec la SK2 , il est facile d'attribuer et ajuster des sons différents pour les claviers supérieur et inférieur . Il ya des boutons pour tordre rapidement l'overdrive , effets , reverb, graves, la fréquence , le gain et les aigus , et 10 assignables "favoris" boutons . Vous pouvez avoir un B3 sur le nez dans le clavier haut et , disons , une réplique près d'un Wurlitzer sur le fond . Il ya aussi une chanson graveur / enregistreur ( si aucun playback préchargées ) , et la SK2 détient 100 utilisateurs et 100 presets . Tant le SK1 et SK2 ont le même nombre de presets , qui , la société notes , représentent chaque orgue Hammond jamais fabriqué . Vous pouvez également aller à hammondorganco.com de télécharger des voix d'extension libre ; Hammond prévoit de mettre à jour la bibliothèque des configurations plus de roues phoniques dans un avenir proche .
Mis à part les organes , les Wurlitzer , clavinet et de piano presets sont parmi les SK2 meilleur, si ce n'est pas un guichet unique . Le laiton et flûtes et beaucoup d'autres sons orchestraux , d'ailleurs - peut sonner en conserve. La sélection du SK2 de presets de piano est vaste , un plus indéniable . Les émulations Wurlitzer résistent bien , mais certains sons mince quand vous clouez la note . Pour mon argent , le Nord Electro est encore mieux Rhodes et Wurlitzer sons de piano électrique , mais Hammond est de combler l'écart et l'emporte sur les tons du Nord d'organes. Et il ya plus de quelques presets du synthétiseur , qui , encore une fois , sont admirables mais pas assez convaincante pour justifier l'échange de votre synthétiseur courant .
Les sonorités d'orgue magnifiques sont le pain et le beurre de la SK2 . Il ya beaucoup de jazz et de rock des options , ainsi que d'un certain nombre d'organes de l'église ( gentiment donné des noms tels que «louange calme », « louange dramatique » et « louange de réflexion " ) . A noter également : l'action chute Les touches de droite est sur ​​l'argent pour un Hammond .
Le SK2 a un seul jeu de tirettes , de garder les commandes aussi simple et directe que possible , selon le fabricant . Vous pouvez basculer entre les claviers supérieur et inférieur en utilisant un " timon sélectionner " bouton . Pour les joueurs qui aiment Hammond difficiles à modifier leur milieu de performance sonore , c'est un peu ennuyeux .
Trop souvent, les manuels d'utilisation du clavier peuvent être plein de jargon technique , presque impossible à déchiffrer. Rien de tel avec le guide de l' SK2 , qui était facile à suivre . Et tandis que Hammond vend un certain nombre d'accessoires pour plusieurs claviers , ils sont aussi offrir le lourd , de type B3 EXP- 50 pédale spécifique à la SK1 et SK2 .
Avec le SK1 et SK2 , Hammond est un bon début, mais a du chemin à faire pour être en mesure de rivaliser avec d'autres , de meilleurs synthés orchestre sur le marché encore . Quand il s'agit d'un son d'orgue classique dans un instrument mobile , cependant , ils sont inégalés .
j'avais pas osé mettre le petit nègre traducteur google :):)
Ah ben, ça y est, on sait maintenant qui passe les annonces foireuses Hammond sur le coincoin.
alapar
Message par alapar »
Merci pour cet article, et pour sa traduction pour ceux qui ne maitrise pas trop bien la langue d'outre Atlantique (comme moi par exemple).
étant possesseur depuis plus d'un an du dit instrument, et si j'ai bien compris il y en a quelques autres sur ce forum et peut-être des futurs (n'est-ce pas Bruno :oops: )
Je voulais faire une proposition de créer dans cette rubrique de clones hammond des sujets (si possible verrouillés pour qu'ils soit toujours en tête de liste (on dit épinglés je crois)) pour chacun des clones dont les membres du forum en sont possesseurs comme XK1, XK3, SK1/SK2, Mojo, Keyb, etc....
Chacun des utilisateurs réels pourraient y mettre des astuces, des liens de documentation ou discussion spécifiques, des liens de fichiers de sons, patch, firmawre etc.. afin d'aider les nouveaux utilisateurs de ces instruments.
Ce qui serait aussi intéressant c'est que ces sujets restent vrai dédiés à l'entraide et reste bien dans le sujet et la courtoisie du partage constructif :lol:
C'est juste une idée en passant, je ne sais pas si ça intéressera grand monde, ni si les utilisateurs sont prêts à prendre de leur temps pour ça, en tout cas avec ma faible compétence, je suis tout à fait prêt à échanger sur le SK2
à voir avec les spécialistes du forum et JCD bien sur.
sinon je peux toujours partager ce que je sais et ce que j'ai en MP.
comme le fait aux USA avec beaucoup de gentillesse Jim Alfredson, avec qui on en est même venu à échanger des patch de son qu'il a utiliser sur ces CD ou vidéo sur tutube.
Hammond C3+ leslie 122, Hammond SK2.
Je pense que pour stocker des docs ou patches, Audiofanzine serait pas mal indiqué, c'est ce que j'ai fait pour un expandeur piano que j'aime bien.
Pour la discussion sur ces instruments c'est mieux ici, sûrement.
ça fait qq jours que je suis la tête dans le SK2, car, bien entendu, les patches d'origine pour faire vendre en magasin...sont catastrophiques pour la plupart, on dirait que le gars qui les a fait a bossé chez korg ou roland et qu'il voulait montrer ses capacités de "synthé" :) :) :)
Bon, les sons piano, cuivres, etc....je n'en parlerai même pas, d'abord il sont juste corrects mais surtout, comme je suis avec une leslie 3300, ce n'est as du tout adapté à ces sons.
Par contre Hammond à prévu qu'on puisse sortir le son d'orgue par la 8 broches (pour leslie 3300) et les extra voices par les sorties jacks et ça, c'est une super idée.
Pour le reste, suis en plein réglages à côté du B3 et il y a du boulot pour que ça ne sonne pas comme un B3 de 58 jamais entretenu :) :)
les claviers sont top, meilleurs pour moi que les XK3c et NewB car, enfin, quand on touche une note à,peine...ça ne déclenche pas (comme sur un B3) alors qu'avec les XK le moindre effleurement déclenchait la note....
La simulation leslie me parait bonne, mais c'est pas ma came :)
Bien sûr mes réglages et patches seront dispos et téléchargeables sur 2 ou 3 sites dans qq semaines, si ça vous tente.
Il me faut en general une dizaine de jours pour bien posséder un instrument et tout ses réglages donc en ce moment je ne joue plus que sur le SK et j'attend d'avoir fait qq concerts pour apporter mes petites modifs au fur et à mesure, le live étant le meilleur moyen de jauger ses réglages.
A bientôt donc à ce sujet, mais ça sent bon....trés bon....
Ah oui, aprés quelques tâtonnements, j'ai enfin retrouvé mes grosses basses....celles que je n'arrive jamais à avoir sur C2, il me parait évident que le preamp du SK2 est trés au dessus des autres marques qui ont une fâcheuse tendance à le sous dimensionner légèrement....AMHA :) :) comme on dit sur cul de chèvre
ah oui, j'allais oublier, le pédalier 20 notes rallongées est trés réussi, mais bon, c'est exactement ce que j'ai demandé à Hiromitsu ONO en 2006, quasiment au mm prés....et qui n'était soi disant pas réalisable à l'époque, cette fois, c'est vraiment jouable sans étirer le pied gauche et la jambe à fond ce qui était inconfortable et fatigant .
Merci donc à Hammond....cela dit, ce genre d'idée trés précise...la prochaine fois, je dépose ! même si c'est pour offrir ensuite, question de principe....Alain Kahn et andré Thus étaient présents lors de cet entretien et pourront confirmer.....allez au final, l'important c'est de l'avoir à dispo.
Merci pour l'analyse détaillée, même si je n'ai pas de sk-2, on voit vers quoi il faut aller et les efforts de Hammond.
Je cherche désespérément un propriétaire de xk-1 qui aurait également eu un B3, de manière à déterminer les bons paramètres de key clic, percu et pédale.
Si d'aventure une bonne âme...
alapar
Merci Bruno,
bien entendu ce sera un grand bonheur pour moi d'écouter ce que tu auras pu faire comme régales sur ton SK2.
En plus si tu les mets à dispo c'est que du bonheur.
D'autant plus si j'ai bien compris avec la version 8 on peut tout sauvegarder individuellement, les réglages leslie et les réglages de son.
à suivre avec beaucoup d'intérêt. :P
zan, j'ai ici 3 consoles, aucune n'a le même clic ni le même son, les percus se règlent sur les B3 donc là aussi ça dépend de l'orgue...la seule chose que peut faire un organiste c'est de regler son instrument en fonction du B3 qu'il préfère dans son entourage, ou tout bêtement de se faire un son qui lui convient...je serai plutôt dans cette optique....un réglage au feeling et ensuite on compare.
En gros avec les propositions pré réglées du SK2 on a au moins 3 possibilités de B3 dont une clean et 2 B3 plus "sales" qui couvrent 90% des orgues mais en partant de là on peut affiner considérablement.
A préciser qu'il y a 2 niveaux d'équalisation, le premier en interne avec reglage sur le lcd et le second avec réglages direct par potard sur l'orgue, idem pour reverb dont on règle la longueur sur le menu mais bouton externe pour sa répartition.
franchement, facile a appréhender, c'est la partie extra voice qui peut être un poil compliquée en live, mais je vais m'en servir 3 fois par an et encore....donc je reste scotché à la partie orgue.
en tous les cas, hier soir c'était impeccable, j'ai juste changé qq réglages sur la 3300 par rapport au XK mais je reçois par hammond ce jour le cable 8 broches direct leslie qui devrait changer un peu ma vision actuelle....en bien :)
Merci Bruno.
En fait, j'ai trois catégories de question : key clic, percu et pédale.
Pour le timbre B3, je me suis fait mon idée par rapport à ce que j'aime (son B3 Supertramp ou Tracy Chapman au début), le matériel que j'ai et le son du groupe. Mais typiquement je laisse tout à peu près droit, et sculpte le son sur le préampli à lampe externe.
Percu : le vol 12 initial du xk-1 donne un son caricatural écoeurant, dont ma courte et lointaine mémoire du B3 ne garde pas trace. Curieusement, mon guitariste adore, et trouve que "c'est ça, le B3". Passons. J'ai mis le vol à 9, typiquement pour jouer Cookin' de Mauri Sanchis, la plupart du temps je reste en soft.
Key clic : à aussi, ça doit varier entre les B3. Deux réglages : enfoncement et relâchement. Quand on n'a pas de B3, on sait pas...
Pédale : là aussi, on cause de notion de niveau min (position talon) qui m'est familière depuis le xb-1, mais aussi d'effet de filtre qui diminue les aiguës quand on baisse la pédale ?
Comment ça marche un B3 sur ces aspects, telle est en résumé ma question finalement ?
Modifié en dernier par Zan le ven. févr. 07, 2014 9:46 am, modifié 1 fois.
en reglant a 6 pour les 2 parametres de clic c'est ok pour moi
Philippe Hekimian
salut bruno
tu me rassures sur le son d'orgue du sk2;j'etais alle me faire une idee chez star music mais les reglages d'usine ne m'avait pas convaincu par rapport au nord.merci
a+
phil.
alapar
Hello Bruno,
et pour ceux qui n'ont pas la chance d'avoir une Leslie 3300 ou autre, et qui sortent directment sur la sono, est-ce qu'on pourra aussi avoir des idées d'amélioration ?? :oops:
les réglages seront les memes car je m'attaque aux paramètres globaux, ensuite on choisit direct out( pour le 8 broches vers 3300) ou sortie jacks et pour les presets réglés pour le direct out il suffit d'enfoncer le même bouton pour repasser en jack et comme la memorisation se fait en 3 secondes...
un peu plus tard je bosserai sur la simul leslie mais je la trouve excellente d'usine, juste un peu lente à s'arrêter ....
hier soir il a tourné comme une horloge et j'ai bossé dessus cet am encore quelques jours et je pense que pour le concert du 15 avec Fabien Mary, tout sera impeccable.
Au fait Phil, je te passerai le fichier des réglages à moins que tu veuilles passer l'essayer chez moi, juste à côté du B3 et sur la même cabine, ça permet de se faire une vraie idée.
Philippe Hekimian
merci bruno
pour l'instant j'ai toujours mon nord electro 3 et mon mac avec vb3 que je ne sors plus:
la carte son ,le cable fire wire ,le cable midi,l'alimentation et gna gna gni,j'en ai marre....
de plus je suis dans la variete a fond en ce moment et j'ai ete oblige d'achete un yamaha motif xf7,belle machine mais toujours l'eternelle surenchere... pour faire des nappes et des violons en plastoc....
je sais, je sors du sujet mais un peu de rebellion bordel!!!
amities
philippe.
m'en parle pas....suis un peu dans le même trip depuis qq semaines, mais à partir de ce soir et jusque fin mars.....que du jazz....ça rapporte peu, mais au moins, on fait de la zique :)
Ah bon dieux que c'est dur ce metier ....
Quand je penses que pendant ce temps la y'a des
privilegies qui font les trois huit chez renault a visser du boulon
3500 fois par jour pour une paye de crevard .
C'est vrai j'vous plaint les mecs .
Y'a pas d'justice tiens ! :D
